Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-25-2012, 10:25 PM
Jim2005 Jim2005 is offline
96 Olds 88 quits, but restarts right away.
I have a Olds 3.8 series II and it will just quit. It will may quit cruising down the highway or sitting at a stop light. I have changed fuel pump, fuel filter, fuel pressure regulator, changed spark plugs and one coil pack.
any help would be GREATLY apreciated!
Old 05-26-2012, 09:08 AM
maxwedge maxwedge is offline
A990 racer
Re: 96 Olds 88 quits, but restarts right away.
Many things can cause this, dirty throttle body, bad or dirty idle air, control, sticking egr, to name a few.
Old 05-26-2012, 09:16 AM
It is worse when the temperature goes up. Yesterday, running the A/C it quit 5 times.
Old 05-26-2012, 10:47 AM
Tech II Tech II is offline
I agree with Max, you may have to clean the throttle body bore and the pintle of the IAC valve, and it's mating passageway......
All these parts were replaced because of a stall?
Why one coil pack? Was there a misfire?
Any codes set?
You have a stall, with immediate restart.....usual symptom of a bad crank sensor, is a stall and then a delayed start.....but have seen them, act the other way too......could try tapping the pedestal of the crank sensor with a long extension, while the car is running....if it stumbles that is your problem......HOWEVER, YOU SHOULD PRACTICE THIS WHILE THE VEHICLE IS NOT RUNNING, DUE TO THE CLOSE PROXIMITY OF THE ROTATING SERP BELT! Don't try his if you are not confident doing it.....you don't want that extension to be caught by the belt...
Another possibility is the connection at the crank sensor and the ICM.....grab the harness and give it a tug while running.....in fact, give a tug on all the harnesses in the engine compartment.....
Last, you could try a tap test on the PCM.....use your fingers on the top of the cover, engine in drive, brake applied, 1000rpms......use another person to help do this.....
Accord quits running,but restarts right away rebelvance Accord/TSX/Accord Hybrid 4 11-16-2009 08:05 AM
99 Alero will start but dies right away Shannonmm1127 Alero 12 07-01-2008 11:51 PM
88 camaro with 305 tbi starts but stalls right away camarocrazy17 F-Body Problem Diagnosis 1 05-30-2007 11:58 AM
89 astro stalls but resterts right away keith12 M Bodies 4 05-07-2006 08:51 AM
1990 Chevy Lumina Starts fine but dies right away mattfox82 Lumina 0 04-21-2005 02:29 AM
