Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 05-25-2012, 08:55 PM
edwinn's Avatar
edwinn edwinn is offline
Buick Enthusiast
Engine module firmware update
Some really good mechanics in the area have tested for and advised that an Engine Module flash (or EPROM update) is available for my 1997 Riv. The price of the software is $75 plus labor (electrical installation.) It's affordable but what can be expected from new engine code? Will there be any noticeable performance increase? Will it run better on cheap fuel? (the fuel in North Virginia is lousy, unlike in California.) Will the engine idle smoother than it used to?
In short, will I feel or notice any difference?
-Ed
Old 05-26-2012, 08:41 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Engine module firmware update
Click Here and enter your VIN in the appropriate box to see the reason for the new software updates.
Old 05-26-2012, 10:38 AM
Tech II Tech II is offline
Wow....our shop never handled it that way, as far as I remember(Buick Dealership).....if you came in with a driveability problem, and an update was available to fix it, we would charge you for diagnosis time, and the time that it took, to hook up our computer to the vehicle, to download the new program, and any other extra programming that might be necessary(like a crank variation relearn)........it was all labor, and I don't recall a charge for the programming......especially since the programming might have been a necessary fix, due to a flaw in the original programming....
The Following 2 Users Say Thank You to Tech II For This Useful Post:
edwinn (06-07-2012), HotZ28 (05-26-2012)
Old 05-26-2012, 12:36 PM
HotZ28's Avatar
AF Moderator Elite
It would be better & cheaper to just purchase another PCM that is already programmed to your VIN with all updates included. It takes about 15-min to install. Click Here BTW, I have used this vendor several times & never had a problem.
Old 06-04-2012, 05:25 AM
edwinn's Avatar
Buick Enthusiast
I see the following listed:
"Change to correct 3-4 transmission harsh upshift and enhance post 02 sensor diagnostics, Bulletin Number 876520."
I've had hard up-shifts into OD under certain acceleration conditions. If that can be solved, then it's worth updating the code. Why didn't the head mechanic at another shop tell me about this when I had a Trans Flush a couple years ago?
-Ed
Old 06-04-2012, 12:16 PM
HotZ28's Avatar
AF Moderator Elite
What was the date of the software upgrade? Maybe it was after you had the trans serviced, or the head mechanic simply was not aware of the update.
Old 06-04-2012, 12:47 PM
edwinn's Avatar
Buick Enthusiast
I'm not sure what the codes mean, and there's no dates given. The info is: ID=238, Part Number= 9365124, Cal.ID#=9365091, CVN=N/A.
It's referring to Controller: PCM/VCM Powertrain/Vehicle Control Module
But that doesn't sound like an ECM, however there are other engine part numbers for "Control Module Cal History."
- Fix for trouble code P0121
- New Cal for improved speedometer accuracy
- Control Module calibration
The above three plus the trans shift fix. So it's confusing.
-Ed
p.s. can the ECM "learn?" meaning if you drive around town, does it normalize to that type of driving? Conversely if driving 1,000's of miles across the country, will it "learn" highway type driving? Not sure where I got this idea.
Old 06-04-2012, 07:05 PM
enslow enslow is offline
How would we know if the calibration has been performed?
Old 06-05-2012, 06:54 AM
edwinn's Avatar
Buick Enthusiast
The tech said there's an update available for the ECM but didn't provide any version number or information about it. However I was standing there in the shop where they had a PC on the bench in front of the garage bay pulling-up database webpages. This was while the tilt-wheel was apart and they were machining new pins.
I'm pinging the group on what to expect from an engine firmware update. Should go over there today and ask them. The vehicle is back in the shop today for a minor "revisit" on the title wheel.
For that matter, he could have pulled up this discussion thread in front of the car with hood open!!
-Ed
Old 06-07-2012, 05:20 AM
edwinn's Avatar
Buick Enthusiast
I asked Mike at Chandler yesterday about the "update" and they don't simply plug in a "reflashed PCM" but actually burn the firmware into the controller with a cable. I'm unaware of any updates (no mention by any shop, or never appeared on an invoice) in the entire 15+ years of owning the vehicle, and have to conclude the firmware is pretty much stock, or a very early version.
If the update will improve/correct the 3-4 upshift (which is rough under certain acceleration conditions) then it would be worth it. There's also a TPS engine code mentioned: http://www.obd-codes.com/p0121
I'd like to see a more comprehensive software revision table and will find our what the current installed revision is.
Question: are we talking about the ECM (engine) or PCM (?) One is the engine module and the other is Powertrain? Which does this update apply to? Is that box locted on the firewall opposite the driver near the fender?
-Ed
Old 06-07-2012, 07:17 AM
A little terminology here.....
Basically, the ECM and PCM are the same thing....engine control module vs powertrain control module......
The ECM was used before OBD II......it basically just controlled the engine......when OBD II came along and then the transmissions were controlled electronically, instead of hydraulically, now the module controlled the engine AND the transmission, and became a PCM.....
Newer vehicles today, now have a module just for the engine, and one for the transmission....they are called ECM's and TCM's....
Old ECM's were not "programmed"....you would just change the PROM to update it.....costly and time consuming......then in the early '90s EEPROMs were used.....you would "reflash" the EEPROM....in the beginning, it was done with the Tech I and later Tech II scan tool......now, they hook the car directly to the PC and download new programming into the PCM....They do it for other modules in the vehicle too....
Since you went to the dealership, it would have been very easy for them to show you the updates to the PCM on your vehicle......you then click on the updates, and they tell you what the update does to the vehicle.....most updates don't increase performance, per say......they usually fix glitches in programming for various sensor inputs.....
The Following User Says Thank You to Tech II For This Useful Post:
edwinn (06-07-2012)
Old 08-08-2012, 06:59 PM
edwinn's Avatar
Buick Enthusiast
Was at the local Buick dealer today where they installed updates in Control Module 16231304 for trouble code P0121, Cal for Speedo accuracy and reduced spark timing error, #9365124 correction for harsh 3-4 shift upshift and enhanced post 02 sensor diagnostics.. all for an electrical labor charge of 110 smackers. There was no charge for the software. Seems to be running as good as ever. The trans update was supposed to hold 3rd gear longer before going into OD? and not to 'bang' OD like it used to under acceleration.
The engine started instantly and ran GREAT. Not a single issue to report.
Ha! they said I needed plugs and wires
-Ed
Old 08-08-2012, 10:27 PM
HotZ28's Avatar
AF Moderator Elite
Like previously mentioned, you could have had another PCM programmed with the latest updates and changed it yourself for less money. Anyway, glad to here it is running better.
Old 08-09-2012, 04:28 AM
edwinn's Avatar
Buick Enthusiast
Thanks Z,
I looked through the Service Manual, Vol-2 and on page 6-571 is an illustration of the PCM location with two parallel connectors and bracket. Apparently it's mounted under the passenger compartment dashboard ?? There's no text describing where it is, but the diagram shows what looks like the outline of the forward passenger door frame and a bold arrow pointing FORWARD to front of vehicle. For this task I needed someone that knew exactly what they were doing and could verify the correct codes. The other shop wanted over twice as much, charging for the software AND labor.
-Ed
Old 08-11-2012, 11:17 PM
HotZ28's Avatar
AF Moderator Elite
Most OBDII PCM's are located under the hood, not under the dash.
1999 Jimmy SLT 4x4 module? cdn_pilot Jimmy 1 01-24-2010 04:05 PM
Need for a new wiper control module KronVickan Crown Victoria 0 05-07-2009 03:47 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 02:53 AM
Japan: New engines and styling update for the Honda Edix - Automotive World (subscription) Automotive News Automotive News Desk 0 12-07-2006 08:30 AM
engine module with different barcode laddy Rodeo | Passport | MU 0 10-07-2004 10:21 PM
