| Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum! |
shaving bodykit
im considering getting a body kit. if i do, ill be getting the bw/spiderman, whatever the hell its called now. anyways, i was wondering how easy it is to fill in holes with bondo/fiberglass sheets, etc. if you could let me know all the different products i would need and how to do it. heres a pic of what i want to do...
i want to fill in the left exhaust side, since its not a dual car.(whoever made a dual exhaust kit for a 4th gen accord is a complete idiot) and i also want to fill in the pair of holes on the sides of the radiator. thanks.
well - Theres been a thread for a while now going around about how to make your own body kit. I'd use the same technique for fillin them holes in :
1) Get styrofoam, shape it so it fits the holes and exhaust cut out 2) get contact cement on the foam, then add foil over it so its all covered w/ foil 3) Let it dry completely.. if not sure if its dry, just let it sit bout hour. 4) Contact cement the sides of pieces your placing in the holes and exhaust cut out, then slide them inside the holes 5) let it dry.. 6) Get Fiber Glass and Resin, mix em' together, and apply about 5 layers over the peices in the holes you made, and about 3-4 inches on to the actual bumper. 7) let it dry, hair dryer will help it dry faster. 8) sand it down so its perfectly smooth w/ bumper 9) primer spray it, then sand again if its not completely flush w/bumper 10) then the peice should be in, fiberglassed, and dry, NOW paint it 11) then add your clear coat Everything but the contact cement and hair dryer should be at yer local AUTOZONE -or- ADVANCED AUTO PARTS. Good luck if u try this.. not too hard, just patience !
Civic - Trashed it Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree.. New Plans : Teggy / or / Tiburon |
