Go Back   Automotive Forums Car Chat > Fabrication & Tools > Other
Other Other fabricating topics.
Old 03-04-2005, 03:24 AM
Electronix_etc Electronix_etc is offline
Shaving in bodykits Very detailed instructions please?
Can someone give very detailed instructions on shaving in a full bodykit starting from prep, to stripping paint to using the stuff(special putty) TSC sells, to sanding to primering. All that one can do without a welder. And using fiberglass is no problem at all(make fiberglass enclosures all day). So please someone give me a step by step instructions. Thanks.
Old 03-04-2005, 02:49 PM
CashMoneyInd CashMoneyInd is offline
You could probably use the box at the top of the page. It's called a search engine. It is your best friend. Just for future reference....
Old 03-04-2005, 02:51 PM
There is the cheap way, in which you use bondo. Then there is another method i am not actually sure of. It requires sanding and fiberglassing.
Old 10-27-2005, 02:03 PM
Re: Shaving in bodykits Very detailed instructions please?
i found fibertech to work the best. There's this putty that comes in a tube called "fibertech" and it works the best. sandable and flexible.
Old 10-27-2005, 06:02 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
cat hair?
just a suggestion though most just use Bondo or Filler with fiberglas shardss in it.
