Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series > N-Body Problem Diagnosis
Old 05-21-2012, 11:55 AM
pcase25 pcase25 is offline
1986 oldsmobile cutlas ciera electrical problem
hi, i have a 1986 olds cutlas ciera im having problems with. ive had my battery altenator tested an there both good ive gone thru an cleaned all my grounds, the problem is that the battery is draining on me. ive tryed adding a new ground to fix the problem but it hasnt worked. i think the problem is in my headlight circuit but i have no clue how to diagnois the problem any one know where to start
thanks pat
Old 05-21-2012, 12:00 PM
maxwedge maxwedge is online now
A990 racer
Re: 1986 oldsmobile cutlas ciera electrical problem
Have you actually checked to see if there is current draw when the car is shut down?
The Following User Says Thank You to maxwedge For This Useful Post:
pcase25 (05-21-2012)
Old 05-21-2012, 12:04 PM
no i havent im about to go work on it so that will be the first thing i check thank u
i can start the car drive it around an for some reason its draining on me last night driving home with it it started to die out while the headlights were on an when i shut them of it was running fine then this morning i went out to start it an the battery was dead
93 Oldsmobile Cutlass Ciera -electrical problem(?)- Iampoison Cutlass Series 3 10-06-2008 11:35 AM
92 Cutlas Ciera Blinker Problems dfjr2323 Cutlass Series 7 10-29-2007 11:42 AM
94 cutlas ciera electrical problem wcharles25 Cutlass Series 2 05-25-2005 02:57 PM
91 Cutlass Ciera electrical problem johnchimpo Cutlass Series 2 09-29-2004 09:48 PM
1991 Oldsmobile Cutlas Ciera Auto Transmission coldon Cutlass Series 2 01-22-2004 05:29 PM
