Go Back   Automotive Forums Car Chat > BMW > General Discussion
Old 05-19-2012, 05:11 PM
FERRARI_JUNK FERRARI_JUNK is offline
BMW E38 740i M60 4.0 V8 motor,erratic fuel pump pressure HELP PLEASE
Hi,i recently got a good deal on a E38 1995 200,000km BMW 740i and i've started having this annoying issue where the engine sputters (its like it hits the rev limiter) whenever i punch the throttle (even in Neutral),it does it at around 3-4000rpm.
It can be driven as long as i dont punch it.
I tested the fuel pump and i am getting 45psi idle pressure then when i step on it,the pressure goes down a bit and then just jumps randomly to 30 then 50psi,essentially cutting power to the engine.
THIS IS WHAT I DID:
-tested pump relay with my e39s relay
-swapped the MAF from my 540i and still the same
-changed fuel pump this morning,still the same
-tested ground to fuel pump
-tested current to fuel pump for fluctuation and its all good
-fuel filter was removed when i did the pressure test and it still happend so thats not it.
-i have magnaflow catalysts so no problem with air flow
*i dont have a CEL on but it does come on momentarily as the engine cuts off,i did the pedal trick and i get 1215 which is air mass flow but it does the same thing with a different MAF and with the MAF removed.And i dont see how it would affect the fuel pressure.
What could it be guys?What could cause the fuel to cut off like that ?please i need some help to get going again.
http://www.youtube.com/watch?v=ysYiGqvFCoE
help please. 84 yota fuel problems CBRrider Pick-Up 8 12-01-2009 08:16 PM
Fuel Pump Pressure S/10 4 Banger chevy 64 Problem Diagnosis 1 05-05-2008 10:27 AM
96 police vic will not start. Checked the fuel pump etc... Help please klein444 Crown Victoria 8 09-23-2006 08:04 PM
BMW 740i 1995 4.0 ( Uses Water ) markcnimmo 7 Series 2 01-24-2006 09:04 AM
2002 Fuel Pump problem, Help please Liquidsteel2 Tahoe 1 10-11-2005 04:31 PM
