Old 05-19-2012, 01:08 PM
Brandybuck's Avatar
Brandybuck Brandybuck is offline
Question Where Can I Find My Engine Specs?
I'm wondering where I can access the manufacturer specifications for my engine - or any engine, for that matter. For example, fuel pressure at different times, vacuum, etc? Is there an online source, or do I need a manual/guide?
Old 05-19-2012, 01:12 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Where Can I Find My Engine Specs?
I recommend a manual if you can find one. Haynes makes a manual for the Grand Prix. I am not certain if Chiltons makes one or not. Amazon is a good place to start.
The Following User Says Thank You to GTP Dad For This Useful Post:
Brandybuck (05-19-2012)
Old 05-19-2012, 01:34 PM
Brandybuck's Avatar
The following link seems to be the only haynes manual available for my '02 Grand Prix. Some of the reviews mentioned that the manual is too vague because it is to broad. What would you say?
http://www.amazon.com/General-Chevro.../dp/1563927268
Specifically, would it contain all the manufacturer specifications like compression values, exhaust values, vacuum readings, and fuel pressure readings?
Old 05-20-2012, 07:44 AM
Pontiac Guy
That is the same manual that I have. It is not as detailed as Chiltons but it is the only one available. I believe that you will find the basic information that you are looking for. If you really want a comprehensive service manual you need to find a factory service manual. They are year specific and are expensive. Most backyard mechanics don't have a need for one as the Haynes is specific enough.
Brandybuck (05-24-2012)
Old 05-20-2012, 07:57 AM
rickisrad rickisrad is offline
If you need anything specific let me know. I can get it for you, nothing I know of in book form or all in one place. as for fuel pressue I believe 55-60 psi, it shouldn't matter at different rpms.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
Old 05-24-2012, 08:09 PM
Brandybuck's Avatar
Thanks, guys.
@rickisrad - My fuel pressure initially bumps up to 50psi on start-up, and rests at 45psi during idle. Sound right?
Old 05-25-2012, 03:29 AM
Sounds good. with the engine running it should be right around there.
Brandybuck (05-25-2012)
Where can I find dimensions, specs of used cars? ChristmasTree Cars in General 1 06-29-2011 10:23 PM
where to find engine specs UncleBenRep Let's get Technical! 0 06-29-2007 01:33 AM
where can i find 2005 or 2006 bora spec ghostowl Jetta/Vento/Bora 0 08-30-2005 10:23 PM
where can find cargo area retractable shade hunter01 S-10 3 03-03-2005 11:12 PM
Where to find Engine Kits and Body Parts Racing101 3000GT/Stealth 2 02-17-2005 09:56 PM
Tags
engine , manufacturer , pressure , specifications , specs
