Old 02-17-2005, 03:14 PM
Racing101 Racing101 is offline
Send a message via AIM to Racing101 Send a message via MSN to Racing101
Where to find Engine Kits and Body Parts
OK, I bought my sister's 93 Stealth ES for $200. Hse got in an accident with it. The front Left fender needs to be replaced...where can I get one? I've looked all over, I can't find ANY replacement parts. It also need a new front bumper if you know where I can find one of those too. It's also got 180k miles on it. I just finished my Dune Buggy, so I am going to do an engine rebuild over the summer while i drive the Buggy. Where can I find a kit for this? I think im just going to do stock internals. I think im going to do Gaskets, Bearings, Piston Heads, Rings, upgrade the Lifters (damn ticking is driving me nuts) and maybe Valves. It's burning oil, so if anyone knows what I should do to solve this, PLEASE LET ME KNOW!
Old 02-17-2005, 03:40 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Where to find Engine Kits and Body Parts
Dude I say you invest in a TT engine instead and use the time you would have been building the engine and work to afford it. I first would reccomend a junk yard, out then check the 3SI.org forums since I know you will find what you need there in terms of body parts for cheep. Good luck and welcome!
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-17-2005, 09:56 PM
PearlGT PearlGT is offline
http://www.nippon-motors.com/index.htm will have some good motors but I would suggest you check out ebay and 3si.org before going anywhere else.
