Old 05-19-2012, 09:35 AM
jbald11 jbald11 is offline
02 park avenue
my 02 park avenue was turning over like the battery was real low, but it was fully charged, then it tried to catch, there was a loud pop, smoke under the hood and now it still turns over a little like battery bout dead, but it isn'tdead.
Old 05-19-2012, 09:58 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 02 park avenue
If the battery checks good, more than likely you have loose, or corroded terminals somewhere. Check all terminals for corrosion and tightness.
Old 05-19-2012, 01:14 PM
Tech II Tech II is offline
Re: 02 park avenue
Agree.....at the battery AND at the starter......it also wouldn't hurt to have a voltmeter across the battery when cranking......key on 12.6 volts.....while cranking, should be in excess of 10 volts.....
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
'95 Park Ave OBDI port location? GMLoyalist Park Avenue 2 04-14-2009 12:57 AM
sensor box 90' buick park avenue Puffy General Discussion 8 08-15-2002 05:35 PM
96' Park Avenue RKE kennyd General Discussion 0 06-12-2002 12:24 PM
