Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-11-2002, 03:00 AM
Puffy Puffy is offline
Send a message via AIM to Puffy
sensor box 90' buick park avenue
i need help on finding out where the damn sensor box is for a keyless remote with fcc id /ab00i03t please
Old 08-13-2002, 03:11 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
RE:sensor box
Are you looking for the Module or the Reciever. The receiver was usually mounted in the trunk under the package or speaker shelf. The module is probably under the steering column.
Old 08-14-2002, 04:52 PM
do you have a picture of what the sensor looks like? cause i checked there and could not find anything that i would think would be the sensor, and the module is a black box correct?
Thanks
Old 08-14-2002, 10:52 PM
Blah blah blah
RE:sensor box
I will check at work tomarrow for a picture. If I have one I'll need your email address to send you the picture. Hope I can help you.
Old 08-14-2002, 11:56 PM
K
Email is : [email protected]
thanks for the help
Old 08-15-2002, 02:01 PM
Thanks again for the help, maybe i can finally get this thing working again.
Old 08-15-2002, 03:05 PM
Blah blah blah
re:sensor box
Anytime. Good Luck
Old 08-15-2002, 05:29 PM
if its not to much trouble could you also send the listing of what the numbered things are in the diagram, i belive ive seen them all in my car, just would like to know what is what.
thanks
Old 08-15-2002, 05:35 PM
Blah blah blah
re:Sensor box
1. remote door lock reciever
2. window glass rear
3. rear body wiring harness
4. rivet
5. remote door lock transmitter
Hope this helps
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
1994 Park Avenue Fuse Panel diagrams? Justin2010 Park Avenue 1 01-17-2010 09:35 AM
1993 Buick Park Avenue, squeaky right front funkist1 Park Avenue 6 01-04-2010 08:53 PM
2000 Buick Park Avenue Leaking from Oil Level Sensor rogerdodger00 Park Avenue 5 01-09-2009 10:08 PM
External Temp Sensor vs A/C - 1999 Buick Park Avenue Ultra The00Dustin Park Avenue 9 09-08-2008 12:40 PM
