Old 05-17-2012, 12:08 PM
notuno notuno is offline
Multiple sudden coolant losses
Hi all, I'm driving an old (1998) Rover 214 and it's been loosing coolant for a while.
There are no apparent leaks, they are sudden losses of maybe 0.2 - 0.4 liters. This has happened at least five times (only once I actually saw the coolant spill on the floor).
When I open the tap of the reserve tank I notice quite a bit of pressure and some coolant flows back up. I took it to the shop and they said it may be a head gasket, but I wonder if it could be simply the pressure cap or something else? I don't want to spend a load of money as the car is almost ready to retire anyway.
Old 05-17-2012, 05:32 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: Multiple sudden coolant losses
Air bubble in the system?
Old 05-18-2012, 10:43 AM
Could be bubbles. How do I find out? How did the bubbles got in (I hadn't changed or refilled the coolant a several months before this started happening)? How do I get the bubbles out?
Old 05-18-2012, 01:51 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
My guess is a head gasket.
Air bubbles cause overheating problems not coolant leaks.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 05-18-2012, 04:42 PM
How much would they charge me to have the head gaskets inspected
and replaced if needed?
Old 06-03-2012, 06:47 PM
bcopeland bcopeland is offline
Water pump.
'87 200sx sudden power loss at 3500 rpm zerk Sentra | 200SX (USDM FWD) 3 02-12-2007 03:39 PM
Sudden power loss on '87 200sx past 3500 rpm zerk 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 01-28-2007 04:12 AM
sudden power loss - 2001 tedzbug Sportage 5 09-18-2006 08:27 AM
sudden power loss dutchct '71-'87 Civic | CRX 1 04-21-2005 10:28 AM
2000 golf TDI sudden power loss Brutalitist Golf 6 06-07-2004 11:38 PM
