Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-14-2012, 03:16 PM
truc0011 truc0011 is offline
Head Gasket replacement - Rocker Arm Shims?
After getting machined Heads will I need Rocker Arm shims? Or can Machine shops make up the difference somewhere?
3.4L, 2003 Pontiac Montana
Old 05-14-2012, 03:32 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Head Gasket replacement - Rocker Arm Shims?
They should not have milled more than .25mm(.010"), If so, the head needs replaced. No need to shim anything, bolt it on and go, the lifters will handle the change.
Old 05-14-2012, 04:17 PM
Thanks - the question came from reading the manual and it says you can add up to two .010 shims to the rocker arm if the head was reconditioned, anthing more than two dispose of the head. It told me to measure the valve stem height but I assume the machine shop would have told me if I needed shims.
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
Head Gasket Replacement rdawg1985 Camry/Camry Hybrid/Vista 16 03-07-2006 10:21 AM
head gasket replacement? nwander Lumina 2 11-13-2004 10:40 PM
Head gasket replacement on an a6 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-20-2003 04:21 PM
1992 Explorer head gasket replacement jmartin7 Explorer | Explorer Sport Trac 1 11-19-2003 10:20 AM
