Old 05-13-2012, 07:59 AM
Mangoman Mangoman is offline
Unhappy 2003 Cavalier headlights very poor
My headlights are terrible. I've cleaned the lenses; replaced the bulbs with the brightest available; re-adjusted the direction. They simply don't illuminate the road well. When another car approaches head-on, my lights seem to be overwhelmed by the on-coming vehicle's lights and it's just plain dark on my side of the road.
Any ideas?
Is this a problem with all Cavaliers?
Would there be a benefit to replacing the entire headlight assembly?
Old 05-13-2012, 04:40 PM
Tech II Tech II is offline
Re: 2003 Cavalier headlights very poor
"I've cleaned the lenses"
Are they clear or not?
Was the intensity exactly the same as originals?
"re-adjusted the direction.......it's just plain dark on my side of the road."
Doesn't sound like it's adjusted correctly.....
There was a campaign on this car to repair the wire harness to the headlights/DRL's.....you would have to go to a Chevy dealer, provide your VIN #, and have them check for any open campaigns on your car.....
Here's what I would do......start car....normal operating temp....lights on.....put voltmeter across the battery......should be about 13.0 volts ......now put voltmeter across the harness to one of the bulbs....the voltage should be the same as across the battery.....if much lower, than you have a voltage drop somewhere.....
Old 05-14-2012, 05:06 PM
Thanks, Tech II !
I appreciate your comments. I just bought the car, so I can't compare what the headlights were originally. The car was parked outside in Miami since 2003. So, I'm guessing it could have corrosion issues from salt air/ humidity.
The lenses seem OK to me.
I'll check with a dealer to see if there were any recall notices.
I'm curious as to whether this is a problem with the model, or just my car.
Old 05-14-2012, 07:25 PM
Did you check the voltage across the battery and the bulbs with the car running?
'03 Sunfires and Cavaliers did have the wiring problem....
Old 05-15-2012, 06:26 AM
Not yet.
I'm flying up to a wedding in New England. I'll have to put that off for a couple of weeks.
very poor acceleration freakyfire05 Lumina 2 01-05-2011 03:14 AM
2003 Venture Headlight Switch Wiring Diagram kapinossa Venture 0 09-19-2009 11:25 PM
Very Poor Idle 2003 Galant 2.4L Inman Lanier Galant 0 08-01-2009 04:38 PM
Very Poor Power/acceleration stinger67 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 05-31-2004 11:51 PM
Driver Information Center - Very very Poor Accuracy Impalian Impala | Impala SS 0 12-11-2003 07:56 PM
Tags
2003 , cavalier , headlights , poor
