Old 05-12-2012, 12:22 PM
Nic8524 Nic8524 is offline
Losing Dash Power When Turning - 08 Grand Prix
Hello,
I have an 08 GP, base with about 83K miles...
For a few months now I've been losing electrical power to my dash when turning. It started out just on my right hand turns, but now I notice it happening when I turn left as well as when I have to brake harder than usual. I don't lose engine power, but I do get the engine chime, the flickering of my dash lights and my radio turns off/on. I've searched around and can't find anyone with the exact problem but I have heard that this could be caused by a faulty ignition switch? Today I took it to the repair shop and the mechanic told me he thinks it is the clock spring but wants to do a $90 diagnostic test to make sure (of course he does). I really do not want to pay $90 for him to tell me, what I told him was the initial problem. Anyone know what this could be? Right now the issue is more of an annoyance but I dont want it to become something major. Any help, or links to other threads where(if) this has been discussed already would be appreciated.
Old 05-12-2012, 12:29 PM
rickisrad rickisrad is offline
Re: Losing Dash Power When Turning - 08 Grand Prix
have you checked all of the fuses and relays in car and under hood? push them all in to be sure they are seated properly.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
Nic8524 (05-12-2012)
Old 05-12-2012, 12:37 PM
FishFind FishFind is offline
One Hot Shot
see if it does it when the car is in park also.
We are trying to see if it is something in the steering column or if it something to do with the car shifting momentum.
The Following User Says Thank You to FishFind For This Useful Post:
Old 05-12-2012, 01:14 PM
checked all applicable fuses and they seem to be in good shape and seated properly. Just tried it in park and the situation im describing did not happen. im almost positive its a momentum related issue because if im turning at a low speed it rarely happens, but if im past a certain threshold or on some kind of embankment (ie using a winding entrance ramp) or braking from above a certain speed it occurs more often.
Old 05-12-2012, 02:16 PM
One Hot Shot
I do not have a wiring diagram for this car but hopefully someone will come along soon that will.
A good way to check it though is to pull out the dash and rub and push the wires and watch to see when it loses power.
You most likely have a short to ground or to the 12v feed. If you wired the radio your self you can see what wire they have in common. They either use the same power or the radio gets power from the dash. Or they use the same ground.
Is anything aftermarket?? alarm, stereo, remote start?
Old 05-12-2012, 04:46 PM
I agree ^^ If all of the fuses are good the next thing to look for is a bare wire or short some where. Like Fish said have the car on and running, wiggle all underdash wires to see if you could replicate the problem. Also look under the engine cover and under hood to see if any wires are damaged there. Sometimes a chipmunk or mouse will get in there and chew the wiring harness. next check the ground wires. Also make sure the battery is not corroded and in good working condition. while the car is on and running wiggle the key around to see if that causes any of the issues you are having.
Old 05-12-2012, 05:48 PM
I have both an aftermarket stereo and starter/alarm on the car. Problem started after I got the starter/alarm put on in abt Nov 2011...I know that still have the warranty for that though. Ill go out and mess w/ the wires and post what I find. Thx for the help guys.
Old 05-12-2012, 06:34 PM
One Hot Shot
I can bet you your problem is going to be where they wired in the alarm/starter. Sounds like a loose wire connection. Not sure on color of the wire but I would guess check the red and pink ones.
Old 05-12-2012, 06:36 PM
One Hot Shot
oH rickisrad. My brothers and sisters all went to Normandy High school. I am guessing yer wife won't know any of them.
Old 05-12-2012, 08:27 PM
yeah probably not.
Old 05-12-2012, 08:29 PM
They may have messed something up in the wiring, these cars can be a wiring nightmare. I would really look at what they did.
Old 05-14-2012, 07:48 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
What did you end up finding over the weekend, Nic8524?
Looking forward to an update,
Sarah
GM Customer Service
Old 05-14-2012, 10:36 AM
Tech II Tech II is offline
I doubt it's a short to ground.....most of these companies use the quick connects that pierce wires, and in some cases, damage the wiring and create intermittant problems......I'd give a tug on the wiring to the starter/alarm system.....
Old 05-14-2012, 04:53 PM
No luck as of yet, I am going to try to get to the root of this problem myself instead of going through the dealer. Anyone know where I can find an instructional on how to remove steering wheel cover/lower dash?
2002 Grand Prix Rear Disk Brake Hub Assembly Removal mtsav8or Grand Prix 1 07-11-2011 10:09 AM
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
Tags
clock , electrical , ignition , spring , switch
