Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 05-11-2012, 05:30 PM
jmcnulty jmcnulty is offline
2005 5.3 vortec smokes on start up
gm made an engineering change to the roker cover gasket. This seems to be the fix so far - 2 weeks no smoke. otherwise always smoked. had valve seals changed 1st -did not work. new baffle on rocker cover -driver side seems to make a much bigger impact then I thought.
Old 05-11-2012, 07:33 PM
j cAT j cAT is offline
Re: 2005 5.3 vortec smokes on start up
driverside is the internal never fail PCV . to fix the cover must be removed . common problem.
on the 2000 5.3L this is not the case. external PCV.
5.7 Hemi V.s 5.3 Vortec busta Silverado 132 07-09-2016 08:05 PM
5.7 TBI to 5.3 Vortec Swap Chevyman15004X4 Silverado 40 07-07-2016 01:29 AM
5.7 vortec towing chaurik Suburban 4 12-07-2011 08:43 AM
5.7 Vortec runs better advanced ++? help wakerider17 Tahoe 5 11-18-2011 03:42 PM
5.7 Vortec SCPI to MFI Manifold Swap 1998_Silverado_WI Silverado 6 08-30-2011 08:25 PM
