Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-07-2011, 08:52 PM
wakerider17 wakerider17 is offline
5.7 Vortec runs better advanced ++? help
Ok, here is the deal
I have recently rebuilt my 98 tahoe 5.7. Had the usual trouble getting the timing and distributor set correctly but she runs good right now. The check engine light is still on, using a scan tool i have found it is because the timing is advanced (+6 to +8). I am aware that the timing should be between -2 and +2 but as I turn the distributor to compensate it boggs down the engine. When it reads a +1 advance the engine light goes out but runs terrible. Like I said it runs great advanced with a little shake but I would like to get this resolved. Any suggestions will be appreciated.
Old 11-08-2011, 01:52 AM
J-Mech J-Mech is offline
Re: 5.7 Vortec runs better advanced ++? help
recheck that the plug wires are in the right order. also, did you get the injector poppets in the right order? (i hope im thinking of the right engine) if you had two injectors that were in close firing order but switched, thatd give you a shake.
Old 11-09-2011, 08:25 PM
Thanks for the reply
The plug wires are all correct and yes this engine has the crappy spider injectors (which i replaced long before the rebuild) all in the right location. However I am now convinced it has something to do with the injection. The link below led me to this conclusion. I just do not have the equipment to do this and I don't want to purchase another one just yet.
Here is the link
http://members.shaw.ca/betterthanyou...g%20Poppet.htm
Anymore thoughts would be appreciated.
Old 11-17-2011, 10:11 AM
I have determined I need to relearn the ckp correlation. They say this has to be done with the Tec 2 computer. My question is can this be done with an obd scanner that Can reset the computer?
Old 11-18-2011, 11:06 AM
777stickman 777stickman is offline
Most likely not. Needs a high end scan tool that can access the "CKP variation relearn". This tool is also needed to set the timing properly (cam offset or cam retard).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-18-2011, 03:42 PM
j cAT j cAT is offline
I would re check the ckp install. make sure its in there correctly.
some have had issues with the install.
it takes a very small change to throw off the computer timing .
a gm high end scan tool has the allowed GM secret program to do this adjustment. you may have to go to the dealership for this . it will be over 100.oo if your lucky..try what I suggested first.
5.7 vortec towing chaurik Suburban 4 12-07-2011 08:43 AM
5.7 Vortec SCPI to MFI Manifold Swap 1998_Silverado_WI Silverado 6 08-30-2011 08:25 PM
please help 5.7 liter hawk713 Caprice 1 04-22-2010 08:05 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
1996 5.7 vortec running poorly boscat43 Sierra 15 11-15-2008 03:05 AM
Tags
5.7 , advanced , ignition , timing , vortec
