Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 05-09-2012, 11:10 PM
98 venture 98 venture is offline
check engine code P340
I looked it up and its "No camshaft signal being received by the computer". Is this something I need to take to the shop or can I do it myself.
Old 01-20-2014, 02:30 PM
partyd partyd is offline
Re: check engine code P340
Unplug the battery for 10 minutes to erase the code and the car will start
but once it warms up you are going to get the same code and the vehicle will turn off again
replace the CAMSHAFT sensor is near the oil filter under the engine
if you have a few extra dollars replace the Crankshaft sensor this is next to the battery, and both use the same reference voltage wire, so it will be a good idea to replace both, also stay away from auto parts. this parts need to come from the dealer only
Old 02-17-2014, 02:38 PM
Searles Lewis Searles Lewis is offline
Smile Re: check engine code P340
I have the same response, replaced the cam and crankshaft sensors, not sure which wire you are speaking of. It will not go all the way over, any ideas?
Old 02-17-2014, 07:25 PM
there are 3 cables in the plug, ground 12 volts reference 5 volts to activate the sensor and the signal that comes out of the sensor.
make sure you have 12 volts ground and 5 volts positive in both sensors, they share the same ground and power signal that comes fromt he computer
Newbie: How do you check the check engine code? johncoby ES300/ES330/Windom 1 10-30-2008 12:25 PM
Checking check engine light codes schneids714 F Series 5 02-05-2005 10:13 PM
1992 Buick Regal check engine code help redlines4us Regal 11 07-11-2003 11:46 AM
need to get check engine code NuEra Engineering/ Technical 0 12-10-2002 02:23 PM
check engine code 10-5 sebaxx Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-16-2002 03:15 PM
