Old 01-20-2005, 05:00 PM
schneids714 schneids714 is offline
Checking check engine light codes
1993 F150 XL with a check engine light that comes on everyone once in a while and then will turns off a little bit later. I was wondering if there was any way to check that code without plugging the vehicle into a computer? Is there some way of checking just using the ignition?
Old 01-20-2005, 07:26 PM
jamfu jamfu is offline
no . autozone does it for nothing
Old 01-21-2005, 10:40 PM
mustangmike351c mustangmike351c is offline
codes
jump two pins on the eec connector under the hood and count the flashes of the check engine light
Old 02-04-2005, 12:20 PM
FORDTRACMAN FORDTRACMAN is offline
Re: Checking check engine light codes
Go to fordfuelinjection.com
Old 02-05-2005, 05:27 PM
wiswind wiswind is offline
I think that you need to have a OBDII system for Autozone to read. The OBDII requirement started with the 1996 model year. A few vehicles had it a year or so earlier, but I doubt that the 1993 had it.
Old 02-05-2005, 10:13 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
not sure if you can pull code with out the scanner. However do not let autozone sell you any parts untill you are sure you need them. They will sell you a shopping cart full of them if you let them. And 99% of them you will not be able to return.
