Power steering rack leak
Hey guys,
I guess I need a new PS rack. It's leaking, I took it to a local shop - they said it's a small leak, so they put stop leak in. No good. What is a reasonable price for a new PS rack, total job, but not counting alignment? Thanks
Current Grand Prix 2008 GP - 174,000 Former Grand Prix's 1994 GP SE - 231,000 1997 GP GT - 134,000 1998 GP GT - 225,000 2002 GP GT - 222,000 |
Re: Power steering rack leak
replace it yourself around $200 for the rack which comes with inner tie rods and replace the outers $12- 60 each depending what brand. It is not hard to replace these if you have the proper tools. At a shop we would charge around $600-700+ to replace the rack and put cheap outers on, then charge for the alignment. and probably see if we could get them to buy powersteering lines on top of that price.
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
While you can buy cheap aftermarket racks from NAPA or Autozone. I would not recomend it. I have had several cases of installing these cheap racks, only to have them leak, bind, have noises, or just plain not work. Sometimes right out of the box, sometimes within 6 months. I would recomend a delco reman gear. While I have also had some problems with them, its not near as often as the cheaper ones.
Whatever you decide, good luck! |
Did the shop show you where the leak was when the car was on the lift?
No. I had the car in for inspection and I asked them to take a look at the leak. As I mentioned, I want to sell this car ASAP, I just need to get it fixed as cheaply as possible.
