Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 05-08-2012, 03:42 PM
RickFromEB RickFromEB is offline
Brake Bleeding
Ok, I have a stupid questioen. I've been bleeding my brakes for about 3 days and have gotten nowhere. I changed out 1 caliper. I haven't touched any of the other wheels and now i keep bleeding fluid and air out and it seems never ending. I've never had this happen to me before and was wondering if this is common and i should just chug along or could there be a problem. I've put a few solid hours of bleeding into it so far. thanks.
Old 05-09-2012, 12:34 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Brake Bleeding
Well, how's the level in the reservoir? Did it go too low during the process? I'm not an expert, but I would think you would have the caliber fully burped in less than 10 pumps. Also, are you doing it properly. Close the valve, brake pedal pressed, open valve, then close, brake pedal released, repeat.
Old 05-09-2012, 12:42 PM
Re: Brake Bleeding
Yeah, i've been on top of keeping the res full and i've been careful about how i bleed so i dont let any air get sucked back in. it's bizarre. never seen this before.
Old 05-09-2012, 10:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Brake Bleeding
How does the pedal feel? I may have misread your post, but you should only have needed to bleed the one caliper you replaced. Do you have access to a vacuum bleeder?
Old 05-09-2012, 11:04 PM
Re: Brake Bleeding
I did only bleed the one. Tonight i continued on my quest and finally got to a point where there were no visible air bubbles. Pedal was still to the floor however i had enough break pressure in the other wheels i was able to take a test drive.after driving a mile or so the hydraulic pressure pushed into the caliper and i have a solid pedal again. i guess it just needed the run around the block. i appreciate everyone's help!
Do I need a scanner to replace brake fluid with ABS brakes? somick MDX | Pilot 1 08-11-2011 01:27 PM
Bleeding brakes is supposed to be simple right? prosystem Engineering/ Technical 5 07-27-2010 08:10 AM
Bleeding 2001 F'in Brakes Nickboudro Silverado 8 02-08-2010 08:09 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
