Go Back   Automotive Forums Car Chat > Honda > MDX | Pilot
Old 08-10-2011, 10:46 AM
somick's Avatar
somick somick is offline
Do I need a scanner to replace brake fluid with ABS brakes?
2005 Pilot with 70,000 miles.
When I replace brake fluid on a vehicles without ABS I use vacuum pump. I have done it many times without any problems. What is going to happen when/if I use the same pump on my son's Pilot? It does have ABS.
As far as I know Honda calls for a special scanner to bleed ABS brakes. I do not have one.
Thanks,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 08-11-2011, 01:27 PM
somick's Avatar
Re: Do I need a scanner to replace brake fluid with ABS brakes?
And the answer is here:
http://www.stoptech.com/tech_info/wp_bleeding_abs.shtml
so I will do it the way I usually do and leave the ABS unit alone.
Sam
Front Brake pads replacement olopezm Grand Prix 8 11-02-2010 11:52 AM
2000 Ranger 4x4 trouble with ABS engaging tjohn2401 Ranger | Courier 1 01-15-2010 09:05 PM
Flushing Brake Fluid for 1994 Explorer with ABS Brakes mike422 Explorer | Explorer Sport Trac 1 05-27-2006 03:36 AM
Need Advice! Brake Fluid disappearing and Brakes have "dead" spots. Un-Mechanic Camry/Camry Hybrid/Vista 3 11-14-2005 03:58 PM
Replacing Standard Breaks with ABS Brakes? crazyitalian1988 Engineering/ Technical 27 01-18-2005 08:14 PM
Tags
bleeding , brakes , scan , tool
