Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 05-08-2012, 12:27 PM
i3igmind i3igmind is offline
Unhappy 97 Infinity QX4
Howdy,
i just bought 1997 QX4 and the main problem with it is high idle @~1100 RPM.
i started by changing spark plugs, and distributor cap and the rotor. took it for a drive and it blew the whole distributor so i changed that
still having the same issue with high idle, so i start at the TB(Throttle body) i went and bought one and replaced it , that included the TPS and also changed the fan coupling because it was bad. now the car idle ~@ 900 RPM.
tested the absolute pressure sensor and that is fine as well i don't hear any vacumm leaks. i am about done with any other ideas (maybe sea foaming the car) but i don't think that will decrease the rpm by ~250
any other suggestions or ideas because i ran out of them
thank you in advance folks
Grinding noise from the front axle in an infiniti qx4 QuismO Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 09-28-2005 07:46 PM
I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4 Apadha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 09-13-2005 08:48 PM
????Shocks/ Struts 98 Infiniti QX4 ???? disel78 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 07-19-2005 08:14 AM
1997 Infinity QX4/ pathfinder Performance parts jbrad37 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 02-28-2005 02:18 PM
Infiniti QX4 vs. Toyota 4Runner igor@af Car Comparisons 14 12-09-2001 11:05 PM
