Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-04-2005, 10:08 AM
Apadha Apadha is offline
I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4
I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4. Thanx Much.
Old 03-15-2005, 08:09 AM
myturnow myturnow is offline
Re: I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4
Try this it's for up to 4 remotes:
Obtain all remotes, close and lock doors, insert & remove key from switch 6 times or more within 10 sec., indicators will flash twice, (Now all transmitters codes are erased.) Insert key into ign. switch and turn to ACC position. Press LOCK button on first remote transmitter to be programmed. Indicators will flash twice to confirm correct programming. To program next remote: Unlock then lock car using driver door button, press LOCK button on second remote. Indicators will flash twice to confirm programming. Repeat for remaining remotes. To exit programming mode, open door. Check all remotes.
Old 09-13-2005, 07:48 PM
rstroud rstroud is offline
Re: Re: I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4
I can't thank you enough. My wife's 98 Pathfinder's remote hasn't worked in months and all along I thought it was a relay.....jsut tried your reprogramming and BINGO!!!! It works again!
