Old 06-03-2003, 03:20 PM
Gainersfuel Gainersfuel is offline
Please Help Me
I've got a 95 Taurus. Here's the problem. When cranking, sometimes it turns and then runs so low it cuts off. Example: I crank it. It's having a hard time turning so I give it gas. It turns after 4 seconds or so but as soon as it turns, it is idling very low and it cuts right off. Now if I quickly throw it in reverse or drive, everthing is normal. I have no clue!!! Can you guys give me some things it could be. I've come up with starter, alternator, fuel pump, tune-up. I dont know much about cars but this is killing me. The car has 115,000 miles on it. The bad thing is that once it's started, its fine. Even if i turn it off. It only happens when it's been off for a while like overnight or so. It sounds like it could just need a tune-up. I hope so. Last time, something like this happened to my Mazda and after over 1000 dollars later, I had a new computer chip or something I had to put in it. It got to the point where it would never start. help me out guys.
Old 06-03-2003, 08:56 PM
pod pod is offline
a tune up would help it sounds like the timeing or the distributor
30 mpg in a brick on wheels isnt half bad...
Old 06-03-2003, 09:39 PM
Ok. If it's a tune-up then thats simple. If it's the timeing, how do i fix that? Is it the same as the timing belt? And the distributor. Is that the same as the distributer cap? Or maybe that stuff is included in the tune-up. Anyway, thanks for the reply. Any other opinions? Anyone?
Old 06-04-2003, 02:19 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
When you turn the key to start it, does it crank slowly?
Beer tastes better upside down.
Old 06-04-2003, 07:34 AM
Naw, it does not really crank slowly. It just takes a little pressing on the gas to start. IT just wont stay idle when It starts unless I quickly throw it into reverse or drive. Sometimes it wont start if I dont give it gas. IT turns just fine. Sometimes though, it starts with no problems. I'm baffled.
Old 06-04-2003, 11:03 AM
Old 06-05-2003, 09:40 AM
A new twist that i just noticed. Like I said above, I have to give it gas as it's turning. When I give it gas, I heard a popping or knocking noise coming from under the hood i think. It would make the noise one time as I give it gas. Does this make things any clearer?
Old 06-05-2003, 11:12 AM
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please Help!! Please Read!!! Please Help!! FromZtoSUV MX-6 0 10-10-2008 08:41 AM
please please please help, please!!!!!!! corolla guy Corolla/Matrix/Voltz 2 08-16-2004 08:42 PM
