Old 06-03-2003, 03:18 PM
Gainersfuel Gainersfuel is offline
Help me Please.....
I've got a 95 Taurus. Here's the problem. When cranking, sometimes it turns and then runs so low it cuts off. Example: I crank it. It's having a hard time turning so I give it gas. It turns after 4 seconds or so but as soon as it turns, it is idling very low and it cuts right off. Now if I quickly throw it in reverse or drive, everthing is normal. I have no clue!!! Can you guys give me some things it could be. I've come up with starter, alternator, fuel pump, tune-up. I dont know much about cars but this is killing me. The car has 115,000 miles on it. The bad thing is that once it's started, its fine. Even if i turn it off. It only happens when it's been off for a while like overnight or so. It sounds like it could just need a tune-up. I hope so. Last time, something like this happened to my Mazda and after over 1000 dollars later, I had a new computer chip or something I had to put in it. It got to the point where it would never start. help me out guys.
Old 06-20-2003, 04:13 PM
dan_taurus dan_taurus is offline
Send a message via MSN to dan_taurus
could be plugs, engine coolant temp sensor,i'm not to sure. have a diagnostic done so it ill be fixed the first time
:22yikes:
Old 12-03-2003, 11:40 PM
Ruben K-Zamora Ruben K-Zamora is offline
Wink
I checked with my Haynes automobile repair manual and it said it could be a fuel-injection problem, a distributor rotor is carbon tracked or damaged, or your battery is low. My guess is to try a tune-up. Your car will not suffer and it is something you can do without much expense.
Also, if there is a code error, take it to a local auto parts store to have the codes checked for free! Good luck.
3300 v6 not firing right help please!!! hyorinmaru Grand AM 8 07-31-2009 03:02 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please Help!! Please Read!!! Please Help!! FromZtoSUV MX-6 0 10-10-2008 08:41 AM
help urgent help please please jasim2005 Grand Cherokee | Grand Cherokee SRT8 19 12-23-2005 12:33 AM
please please please help, please!!!!!!! corolla guy Corolla/Matrix/Voltz 2 08-16-2004 08:42 PM
