Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 05-06-2012, 09:05 PM
dghawk dghawk is offline
93 Olds 98 A/C cuts out
Hi All!!
I have a 93 Olds 98 with approx 98K miles. I have previously (years ago) converted the A/C to R134a. Lately, the A/C has been working fine for approx. 5 minutes, then it cuts out. I had the A/C level and pressures checked Saturday and they are fine (system is full). This weekend, when it cut out, I jumpered the wires at the cycling switch on the accumulator, and the compressor started running again. So naturally, I replaced the accumulator cycling switch. Drove the car again and same result - A/C ran well for about 5 minutes and then it cut out. Has anyone had the same problem and fixed it? Any good ideas? Thanks in advance. Sincerely, Dave.
03 Chrys 300M Special
93 Olds 98
96 Yamaha XV1100S
Old 05-06-2012, 10:16 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 93 Olds 98 A/C cuts out
Could be an air gap that is too wide, next time it quits and should be engaged- tap on front of compressor with a wooden hammer handle- if clutch pulls in- your air gap needs re-adjusted to .020"
Magnetic clutch coils can pull in a wide gap when cold- but after they warm up, it is not able to.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-07-2012, 07:19 PM
That sounds good. I will check the clearance the next time it happens - may be a few days due to work schedule. How do I adjust the clutch if necessary? Is it as simple as tightening the shaft nut until the proper clearance is achieved? Also, is this a possible solution, even after I jumpered the accum. cycling switch and the compressor engaged? Thanks again. Sincerely, Dave.
93 Olds 98
96 Yamaha XV1100S
Old 05-07-2012, 09:28 PM
Tech II Tech II is offline
There is only one way you can "check the A/C level", and that is to recover the freon, pull a vac, and then add freon by weight.....
You said the pressures were checked....what were the low and high sides doing?
This is a CCOT system, so the compressor will shut off and cycle......
You say, when the compressor goes off, it stays off, but if you jumper the harness to the low pressure switch on the accumulator, it comes on?
Since you replaced the switch, you need to have gages on this when the compressor cuts out......see if that low side is going well below 30psi......
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-15-2009 12:26 AM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 08:13 AM
89 olds ninety eight cuts out gilbert3769 Ninety Eight 5 06-07-2007 04:42 PM
1988 Olds 88 cutting out TommyMc Eighty Eight 8 10-18-2005 12:39 PM
90 VW Fox cuts out HELP - when warm does this death / cut out / diesel / chokeded out jamandrew General Discussion 5 04-14-2004 12:53 PM
