Old 05-06-2012, 01:49 PM
HeWhoKillz HeWhoKillz is offline
head gasket
I have an 89 buick century with the little gutless 4 cylinder with almost no power at all. My girlfriend drove out of town about an hour away. She calls me and says the car is acting up. I told her I would be up there to get her and we would figure it out but it would be a couple of hours. I guess she didn't want to wait so she drives the car 3/4 of the way and parks it at an outlet mall about 10 miles away. I go and get her and I get in and start driving the car and it acts like the head gasket went. It misses but its not like when a spark plug is taken out of the engine but rather a heavy sputter and the gutless car's power is reduced to negative numbers as it took nearly a full minute to get up to 45 mph. I figured she had done enough damage to it that everything in the engine had burned up. I get it home and I can see a little bit of smoke at the bottom coming from behind the driver front tire but there wasnt any smoke from under the hood when I opened it. Today I went out to look at it since it sat all night and cooled off. I assumed if it was the head gasket that all of the fluids would have burned out and/or that the coolant would have been mixed with the oil. I look on the dipstick and only see oil. I don't see any coolant in the oil cap and the coolant is still in the radiator. I had a corolla with a head gasket issue and it always burned up the coolant but that was because the thermostat and the fliuds were in fact mixed. Are there any other tests I can do to make sure it is or isn't the head gasket before I put money into a car this old? I bought the car for 200 bucks and had it for almost two years without too many issues but I don't know if I want to put money into something that might just be better off being replaced with something newer.
Old 05-06-2012, 06:08 PM
maxwedge maxwedge is offline
A990 racer
Re: head gasket
Why didn't you post this in the specific Buick Centruy forum? If the coolant is full and no white smoke out the exhaust why a head gasket?
Old 05-06-2012, 09:07 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: head gasket
Maybe a plugged catalytic converter, and the smoke you noticed was due to a REALLY hot converter?
-Rod
Old 05-07-2012, 12:46 AM
vgames33 vgames33 is offline
Re: head gasket
Do a compression check. A friend of mine blew a head gasket between #1 and #2, No coolant loss, but it sure ran like crap. If compression is good, a head gasket can pretty much be ruled out.
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
01 grand am 3400 head gasket? LoMbArD Grand AM 33 10-19-2009 12:29 PM
Head Gasket Leak el ratfink General Discussion 4 08-14-2009 06:04 AM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
'92 SC - head gasket - replace both head gaskets? kaje71 Thunderbird 2 09-05-2008 05:10 PM
