Old 05-02-2012, 04:10 PM
BuickRegal BuickRegal is offline
What would happen if..
What would happen if you put transmission fluid in your radiator and antifreeze in your transmission?
Would your engine run for a minute or two and then seize up?
Old 05-02-2012, 04:38 PM
FishFind FishFind is offline
One Hot Shot
Re: What would happen if..
no it would keep running.
Tranny fluid is a oil. You just need to drain your rad and refill.
worse effect on the tranny. Obvious water and oil dont mix. So you put water in your tranny oil. Also drain and flush, refill. Worse if you drive it like that, a lot worse. If you drain flush and refill fluids you will have little or no problem, if you did not drive with it in there.
Old 05-02-2012, 06:25 PM
maxwedge maxwedge is offline
A990 racer
Sounds like a planned sabatoge.
The Following User Says Thank You to maxwedge For This Useful Post:
FishFind (05-02-2012)
Old 05-02-2012, 08:40 PM
What about antifreeze in the crank case (where motor oil should be)
Old 05-03-2012, 12:26 AM
ricebike ricebike is offline
maybe if the auto transmission cooler that is built-in to one end of the radiator has corroded over time... then trans oil and antifreeze/coolant can mix that way.
Old 05-03-2012, 12:27 AM
yes; possible that your head gasket went south
Old 05-03-2012, 01:55 PM
One Hot Shot
That is bad. How did all this happen
I wonder what would happen if this gets published in the newspaper today... publicenemy137 COMPLETELY off-topic 19 09-30-2004 03:54 PM
What would happen if... D15Bitch '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-10-2003 09:31 PM
Paint combos (layers) ie what would happen if... Toksin Car Modeling 8 11-02-2002 11:56 PM
What would happen if I took that off? Polygon COMPLETELY off-topic 20 09-26-2002 12:44 PM
