Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-02-2012, 10:16 AM
jerry1967 jerry1967 is offline
2001 Buick regal trunk will not open
My electronic trunk will not open unless I use the door key. I don't even hear the clicking sound. I have been having trouble with this for a while. Sometimes it would open and sometimes not. But now I get nothing.
No clicking even if I use the button in the glove box.
Anybody have any ideas what this might be?
Old 05-02-2012, 04:07 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2001 Buick regal trunk will not open
It sounds like the solenoid has gone bad that activates the lock mechanism. Try putting power to it at the solenoid itself. It it operates correctly then check the wiring from the glove box button to the solenoid itself. It is possible that it is as simple as a bad button or contact in the glove box. Good Luck!
Old 05-02-2012, 10:05 PM
Tech II Tech II is offline
Disconnect the harness to the trunk release solenoid....attach a test light to the harness......press release button or use your RKE fob......if you have power, bad solenoid......if you don't, follow the harness back in the deck lid where it goes into the body....have found a few broken wires in the harness, due to flexing at that point....
The Following User Says Thank You to Tech II For This Useful Post:
jerry1967 (05-14-2012)
Old 05-14-2012, 07:36 AM
what does the solenoid look like
Old 05-14-2012, 08:24 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
It's mounted on the latch, look for the connector at the latch. Like TechII said, follow the wires back, around the passanger side hinge for the trunk lid, you will probably find an broken ground wire, maybe two.
Old 05-14-2012, 10:41 AM
Yes, the wiring may be in a loom or taped up......you will have to remove this to look at the wires for a break.....
1996 buick regal occasionally will not turn over swipermike Regal 1 10-14-2005 01:58 PM
1997 buick regal 3800 will not start. deun99 General Discussion 4 10-05-2005 08:58 AM
Electronic trunk will not open at all Patash General Discussion 1 08-04-2005 10:19 PM
1998 Buick Regal GS will not start sometimes jzapper Engineering/ Technical 3 03-15-2005 12:12 AM
Trunk will not open 97killacam Camry/Camry Hybrid/Vista 13 08-26-2004 05:50 PM
