Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 08-03-2005, 11:06 PM
Patash Patash is offline
Electronic trunk will not open at all
I have a problem. My electronic trunk on my Plymouth Voyager 2000 will not open either with the remote or the key. I have been advised to remove the interior panel and attempt to fix it this way, however, I do not know how to do this. Is there a special tool that I need? Where do I get it? Where do I begin to remove this panel?
Also, My driver side window has been disconnected, also electronic, because it gets stuck in the down position.
Thi final problem I am having right now is that my air conditioner is not holding a charge. How much money am I looking at spending to make this care safe for my son and grandson who both have heart and respiratory conditions? and ar these repairs something I cna do myself?
Old 08-04-2005, 11:19 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Electronic trunk will not open at all
If your trunk won't open with the key or remote, sounds like a problem with the latch assembly on the trunk door itself. If the window gets stuck in the down position, you have a bad window switch, simple to replace and cheap, if you go to a junkyard. Your A/C, depends on where the leak is, if you have one. A/C work can be pricey, even if you do it yourself.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
