Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-01-2012, 08:30 PM
chuck0 chuck0 is offline
Thumbs down Fuel injector clip?
I'm re-assembling the fuel rails back onto the LIM (Buick 3.1 L) when I noticed the legs of (1) fuel injector clip were broken & not engaging the rail.
My feeling is that the clip is not needed since the injector is trapped between the rails & the LIM. Maybe the clips are required at the factory only to keep the injectors assembled to the rails before they are later assembled to the engine.
My question is: should I ignore the broken clip & install the injector?
Old 06-11-2012, 12:41 PM
Re: Fuel injector clip?
FYI,
I did ignore the broken clips & installed the injectors w/o them. I have encountered NO problems with the injectors since their installation.
Old 06-11-2012, 03:22 PM
danielsatur danielsatur is offline
1) Clean connection with CRC electronic cleaner and use a little dielectric grease.
2) Apply just a Little RTV silicone on the plastic con + glue it in.
3) Use a small shop vacuum to get lost clip out of the spark plug boss.
Old 06-11-2012, 06:56 PM
I don't have a clue about what you are trying to fix. This thread is about fuel injector clips
that attach to the fuel rails.
Old 06-11-2012, 09:27 PM
There's alot of fuel pressure going to fuel injector, and a clip is used to hold the injector in.
If there's a bolt holding the rail down, it should be ''ok''.
My Bad, the other is for a bad fuel injector, or COP signal wire connector fix.
If the injector under test is bad, any diesel shop can micro bath, blow out, and test the flow rate.
The Following User Says Thank You to danielsatur For This Useful Post:
chuck0 (06-12-2012)
Fuel Injector , Missing spring clip Jmrec100 Cavalier Problem Diagnosis 1 08-24-2010 07:36 PM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
fuel injector clips schetk Rodeo | Passport | MU 3 04-20-2008 11:08 AM
Gas leak, and broken fuel injector retaining clips j_p_lockwood Lumina 10 01-11-2008 04:45 PM
Fuel Injector/Rail clips... NickF829 Malibu 1 08-22-2006 08:34 PM
