Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-19-2008, 01:36 PM
schetk schetk is offline
Angry fuel injector clips
I am replacing the cooling o rings under the intake. I can't figure out how to remove the wire harness at the FI. there are two metal side clips and one metal clip facing the valve cover. How do you uremove these? The manual just says remove and I'm afraid to break them.
Do the fuel rails stay on the intake when you remove the intake? What a pain for two $3.00 o rings on the coolant pipes. Aside from the heater hoses anything else I should replace?
schetk
97 rodeo 3.2
Old 04-19-2008, 01:50 PM
FL 3.2L FL 3.2L is offline
Re: fuel injector clips
I found it easier to leave the rail in place and disconnect the fuel lines.
And you have to squeeze those wires on either side to get the injector connectors to pop off. I remember that being a pain...
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 04-20-2008, 10:04 AM
Smile Re: fuel injector clips
Thanks that was easier.
I am going to replace the valve cover gaskets while I'm in there.
schetk
97 rodeo 3.2
Old 04-20-2008, 10:08 AM
Smart. Get the spark plug tube rings, too.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
