Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-29-2012, 12:22 PM
gosborne gosborne is offline
Need help with wing and uprights
I have been working on the rebuild/restore of my GTWC car (#11) coming up on 3 years and am ready to hang the body and finally get the car back on track.
Where I am struggling is with the wing. I don't have a factory wing or uprights and am starting from scratch here. I did buy the last set of uprights that Eric made but it was after I bought them I realized they were intended to bolt to the existing. My questions are:
1) is the factory wing, if positioned properly, effective and adjustable? I know it was on the car originally for aesthetics and wonder if positioned up and back if it is effective or not since it was not originally designed to be functional. The cost of a factory wing from PAD is quite a bit less than an aftermarket wing from one of several suppliers. If the consensuses is that is it effective, I'll go that route, buy an original wing from PAD, and invest the $$ saved elsewhere.
2) I know there are several posts on this but can anyone provide a pattern or dimensions for uprights and mounting?? Again, I do have those that Eric made but, not sure if I can use those without the factory bits to cut and bolt to or not. I did drill and mount them to the factory location just as an experiment but am not sure they are usable in that manner. They certianly aren't aligned with the factory clearences on the trunk lid/rear quarter so, not sure on that. Again, I have nothing to reference since the car had no uprights or wing when I bought it.
The challenge I have is very limited time to research and experiment and any assistance to help me jumpstart this process and wrap up my build would be greatly appreciated. If anyone has built their own solution for uprights and also a front splitter that they would be able to recreate, I am an interested buyer if it will shorten the time to completion for my project.
Any help would be appreciated!!! Thanks in advance.
Gary
Gary O.
Panoz GT-WC #11 (build in progress)
74 Porsche 911 IROC replica
88 Porsche 944 Cup race car #12 (sold)
Old 04-30-2012, 07:34 AM
panozracing's Avatar
panozracing panozracing is offline
Re: Need help with wing and uprights
I have a CAD file for the one piece uprights that I make to hold the wing in a new position. I also have a paper template of a splitter that you cut from aluminum or plywood and then use a shrinker to make some angled brackets.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-30-2012, 12:42 PM
CMPanoz CMPanoz is offline
Panozracing CAD and template worked well for me. The uprights have held up well also.
Panoz GTWC 2
Panoz GTWC 3
Panoz GTS
Old 04-30-2012, 07:49 PM
Brian,
Thanks for offering to help, much appreciated. I'll PM you with contact info.
CMPanoz - thanks for the feedback
Best,
Gary
Gary O.
Old 05-01-2012, 12:03 AM
CMPanoz - what material did you make the splitter out of? My newest version is cheap 3/8" CDX plywood with a round over edge done with a router then painted with a flat black. It seems to be working better. Stiffer and cheaper.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-01-2012, 08:31 AM
Brian,
I made the splitter out of aluminum, do not recall the gage off hand. It sustained a little damage after the engine failed and I went off track to prevent a mess. I was thinking about the plywood rout but am concentrating on getting the new engine installed.
Chris
Panoz GTWC 2
Panoz GTWC 3
Panoz GTS
Old 05-10-2012, 01:34 PM
Riverside Racing Riverside Racing is offline
Brian, PM sent. I could use the CAD file and the template too.
Thanks,
Tom Whitfield
need help with wing slammedscion Non-Performance 5 12-07-2004 09:09 PM
Need help with Windows and Lighter Ragman26 Rodeo | Passport | MU 0 08-22-2004 05:55 PM
I need help with distruiputor and tranny!!! Dustinb1313 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 03-11-2004 09:22 AM
need help with struts, and fan doesn't work joyrider Cavalier 2 02-15-2004 06:18 PM
Need help with wheels and tires freeman139 Tires and Wheels 2 05-18-2002 04:28 AM
