Old 03-10-2004, 04:11 PM
Dustinb1313 Dustinb1313 is offline
I need help with distruiputor and tranny!!!
I have a 1990 honda civic si, the guy I bought it off of said it has a 94 vtech from a 94 civic, I dunno if this is true but It is from a 92-95 civic cause a mechanic told me this from the numbers off the block.
I have the 1990 distributor and
it does not match with the engine, the guy who had it before me used
washers to bolt it on because the bolt holes do not line up. The distributor is grinding now so I have to replace it, so should I just get another 90 distributor and do the same thing with the washers?
Also when I down shift and let off the clutch the tranny makes a noise, its hard to explain, its only when im down shifting to slow down, when i give it gas the noise stops.
Last question, I got 17 inch rims and on the front right one I have been breaking studs, I probably have broken off all 4 at different times and replaced them, whata causes this? One mechanic said it was from driving to fast or my rims were screwed
Thanks alot
Old 03-10-2004, 05:11 PM
lilol89crx lilol89crx is offline
Re: I need help with distruiputor and tranny!!!
weve used obd0 dizzys on the vtec heads(sohc) and havnt had a prob, although they need to be modified a little.
tranny noise sound like a whiring? mt tranny made a whiring sound when in gear and rolling. in my case it was the tranny mainshaft bearings.
dunno what could cause ur studs to be breaking.
Old 03-10-2004, 06:50 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
I would really recomend you get the proper DIZZY for your car bro that way you can avoid any problems, that may appear in the near future, I dont know about that "MickeyMouse" shit!!! as for your studs breaking: this might be a stupid question but are your wheels bent or anything like that, becuase that's the only thing that I could think of....
Old 03-10-2004, 08:03 PM
What is a Dizzy? Do I keep the 90 distributor or do i need the 94? and how much does this dizzy thing cost.
Thanks
Old 03-10-2004, 09:43 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Re: I need help with distruiputor and tranny!!!
Thanks
Hi Noob (new person), Welcome the the forum (welcome to the forum, j/k (just kidding))
A dizzy is the distributor, and you should use the 94 version of the dizzy so you don't have to Mickey mouse the thing to the engine. The dizzy is expensive, your best bet is to do some shopping around (maybe autozone etc somewhere that offers a warrenty). GL (Good Luck )
Old 03-10-2004, 10:47 PM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Re: Re: Re: I need help with distruiputor and tranny!!!
Dammit John, you beat me to a smartass comment, lol, I'm supposed to be the one to make comments like that... Anyways, good info bro...
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 03-11-2004, 08:14 AM
johnb16a2's Avatar
No problem, I'm here to help and learn, I do what I can.
Old 03-11-2004, 09:01 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
definatly get the dizzy out of the same motor thats in your car.
your studs, could be breaking by being terribly out of alignment, or if they are old and rusty and you like doing burnouts, your just putting too much stress on em.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-11-2004, 09:22 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
I would say to take a look to see if the rims are straight.
Evan
