Old 04-28-2012, 07:38 PM
Anthont.Friend2011 Anthont.Friend2011 is offline
Tire Noise
i have a 99 chevy blazer and i put a little bigger tires on the truck and i am getting a road noise which is fine becuase of the bigger tires but when i turn left or right it sounds like flat tires any one know why this could be happen i went yesterday and got my tires balance and it still happening HELP!!!!!
Old 04-30-2012, 09:40 PM
old_master's Avatar
Advisor/Moderator
Re: Tire Noise
Noise like you're describing is caused by a wear pattern in the tread. When an abnormal wear pattern is worn into the tread, replace the tire, there is no "fix". Any one or more of several things can cause the wear pattern: Incorrect front chassis ride height, incorrect wheel alignment, worn shocks, worn steering linkage, worn suspension parts, worn wheel bearings.
You have to know how it works,
to figure out why it doesn't.
Old 04-30-2012, 10:11 PM
FishFind FishFind is offline
One Hot Shot
Re: Tire Noise
\Turn your wheel all the way to one side put it in park and see if it is rubbing the frame.
Odd wear on inside front drivers side tire tennesseeguy Sable 5 09-17-2011 01:38 PM
wining noise slight when making right turn what is it tire noise or something more tnwhite Dakota 8 06-22-2009 10:04 PM
Tire noise or Wheel Bearing Noise joe n suzanne Park Avenue 5 02-22-2005 06:07 AM
17in Tires Noise bobby Integra 1 11-02-2001 05:56 AM
