Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 11-09-2001, 11:39 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Gear woes
Help me!!! I am having trouble on my 1993 G20 with getting the gear shifter mechanism into 1st. It isn't sliding out of it... IT WON'T GO IN!!!
I know I have the clutch fully depressed, and all the other gears will receive the shaft, but it actually feels like something is blocking the spot in 1st gear. And it isn't all the time, either. Very inconsistent. Sometimes the shaft slides in beautifully, sometimes it takes a second of "convincing" and everything else I end up having to run the engine below 2000 rpms with no choice because I can't downshift low enough to get the power I need
I can't find anything about it on AllData.com and I've never heard anyone else have this problem. Maybe someone can think of another keyword to search for besides "1st gear"....
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 11-09-2001, 11:50 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Your clutch is probably wasted and might need replacing. Or you could just have something loose. Have someone check one of the two.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 11-09-2001, 12:27 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
This may sound like a stupid question, but how are your motor mounts? are they wasted? I know when they get real bad, it can make shifting strange.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-09-2001, 04:04 PM
T4 Primera T4 Primera is offline
According to Haynes:
Difficulty engaging gears:
Clutch fault
Oil level low
Worn or damaged gearchange linkage
Incorrectly adjusted gearchange linkage
Worn synchroniser unit/s
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 11-09-2001, 11:53 PM
speediva's Avatar
Thanx. I'll look into all of those. I haven't had time to get down and dirty yet to take a real look at anything... I'll post back IF I find an answer
Inform yourself:
AF User Guidelines
Old 11-12-2001, 05:53 AM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
I had a similar problem....
Symptom:
-Car wouldn't go into 5th
Problem:
-Bent Shift fork
Cause:
Broken rear motor mount
Solution:
$1726 later
New Tranny
Women call my bedroom the COCKpit!
Old 11-12-2001, 06:40 AM
P10DET's Avatar
P10DET P10DET is offline
This is a relatively common issue with these gearboxes. You might also try searching the SE-R Mailing List archives as well. There doesn't seem to be one single definitive answer to this issue. Some gearboxes are just baulky. Also, rev matching when shifting into first seems to help a lot.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-13-2001, 01:50 AM
speediva's Avatar
Well, no real news yet (I haven't had time to tend to my car with running my own forum...)
I have noticed a pattern to my problem, though... If I'm still in motion coming to a stop, and I'm getting it into first to get started again, it won't budge. (ex: when I'm coming to a redlight going uphill and I get into first as I put on the parking brake so I can get started w/o rolling) But, if I come to a complete stop, there is no problem what-so-ever... Is there some sort of protection on the p10 against overrevving the engine (even though I'm not yet engaging 1st--just putting it in first with the clutch still in to prepare to start)???
I"m scheduling an appointment tomorrow to get it looked at. When I wimped out and got my oil changed at Valvoline they noticed a "slight" tranny fluid leak, so I hope these aren't symptoms of a bigger problem.
Inform yourself:
AF User Guidelines
Old 11-13-2001, 02:55 AM
An oil leak resulting in a low trans oil level could be the cause of your problem - may just need some tranny oil.
-- Bertrand Russell
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
How do I know if I'm in too high a gear uphill? PenguinLust Cars in General 0 01-29-2010 11:44 PM
99 MC Gear Slip, Stalls when i slow down sully313 Monte Carlo 3 10-01-2009 11:52 AM
Transmission woes.. stuck in gear? cardriver Samurai 0 10-03-2008 06:42 PM
