Old 04-24-2012, 10:42 PM
fioretrevor fioretrevor is offline
Whats wrong with my truck?????
Bought a 99' Ford 250 V10 about a month ago. Its got a superchip in it and its set to 87 octane. I plan on taking it out eventually but for now i have plugged it in and ran a diagnostic test on it. It gives me a reading that says that System Too Lean (bank 1) and System Too Lean (bank 2). I have a basic understanding of what an engine running to lean means but dont understand what i need to do to fix it. Also, this truck burns about a quart of oil about every week. I figure these two things have to do with eachother. The check engine light came on a few days ago and the truck is starting to run funny. It doesnt go through the gears at a smooth pace. What are your thoughts of what the heck could be wrong.
Thanks for Your Comments!
Old 04-24-2012, 10:54 PM
FishFind FishFind is offline
One Hot Shot
Re: Whats wrong with my truck?????
What code came up when check engine light came on??
Bank 1 and 2 mean that the side of the engine with the #1 cyl is bank one and bank 2 is the other side if the engine. So both sides are lean.
The oil that you are losing is not good. Are you burning smoke>?
Old 04-24-2012, 11:00 PM
The only thing i have to read code is the superchip monitor you plug in. and that told me it was running to lean. Im not burning smoke. and im using a valvoline next gen oil.
Old 04-26-2012, 04:47 PM
FNA FNA is offline
At a quart a week, if you are not blowing smoke, you are leaking oil, so it is probably a different problem than your lean condition. I couldn't say about the lean condition, but as long as you are going through so much oil, you ought to use cheap oil.
Old 04-26-2012, 04:57 PM
Where should i start as far as repairs go?
Old 04-26-2012, 05:30 PM
tempfixit tempfixit is offline
Look for a vacuum leak, does it run rough??? Get the codes read and post. How is gas mileage?
Old 04-26-2012, 05:37 PM
Seems to shift funny sometimes.when im in drive with my foot on the break at a stop, it sometimes reves up and down without me touching the gas pedal
Old 04-26-2012, 07:05 PM
You might want to check the vacuum brake booster for vacuum leak. or hose from intake to brake booster.
Old 04-26-2012, 07:14 PM
One Hot Shot
I would also say vac leak. the truck will give it more gas if it is sucking in air from a vac leak to keep the gas/air mixture correct.
Old 04-26-2012, 07:18 PM
ok i will definately check that! im starting to think it might be a bad spark plug or wire because it doesnt run really rough but there is a little bit of a shake. what is your opinion on that?
Old 04-26-2012, 07:35 PM
One Hot Shot
if that was the case it should have a code for whatever cylinder is missing.
Old 04-26-2012, 07:37 PM
One Hot Shot
I would check rubber hoses for cracks or any hose that came off of something. check around valve covers and intake manifold. You can put a little transmission fluid or oil arount the valve covers and intake manifold and see if it sucks it in anywhere.
Old 04-26-2012, 08:16 PM
Found this link by googling: Ford V10 Code P0171 and P0174:
http://answers.yahoo.com/question/in...6125723AAzuCT8
Want to know whats wrong with your truck? dfordski F Series 9 03-29-2010 07:07 PM
Whats wrong with my truck? Westell Engineering/ Technical 1 03-15-2009 10:14 PM
Whats wrong with my truck miky14 Automotive Articles 0 11-12-2007 12:23 AM
what wrong with my truck knlath F Series 3 02-25-2007 06:21 PM
