Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-24-2012, 02:41 PM
Richard98 Richard98 is offline
Question Help with light and turn signal problem
1998 Pontiac Trans Am lighting issue.
Hello,
I need some help. I believe I have some sort of wiring problem. So a little back ground....I have a 98 Pontiac Trans Am ( auto ) thats been converted to a M6 6sp ( I paid a shop to do the change) everything worked as it should ....now 3 yrs later my firewall cracked .. The steering colum was removed to fix the firewall . Now I have the firewall is fixedly , car is running but...now I have some issues and could use input...
1. Rear turn signals work / not the front.
2. Hazard lights work in back/ not in front
3. Front park/ DRL do not come on until I turn on the head light switch to the park light position.
4. The low beam lights come on when I turn the head light switch to park light / my head light do not flip up , as they should not with the switch in the park light position . But my head lamps should not be on also .
5. The low beam light goes off when I switch on the high beam ( the lights are in the park light position )
6. Turn the switch to the light on position (thead lamps pop up ) as stated above the low beams are already on . Switch to high beams and there is no change . No high beams . The indicator light is on for high , but no light.
7. The front turn signal do not work ( only the rear ) the dash indicator light flashes as normal
8. The hazard light only work in the rear indicator light flashes as normal
So , anyone have any idea of what may be the problem ?
Any way to check the DRL module
Anyone have a wiring schematic ?
Thx
Richard
Old 04-24-2012, 04:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Help with light and turn signal problem
Since it worked before the column was removed, and not after it was installed, you need to check all the electrical connections that were disconected, inspect all the terminals and make sure none got bent over, check all the plugs to make sure they are all seated properly.
Help brake lights and turn signals dont work gruenejl Neon | Plymouth Neon 2 12-17-2005 12:38 PM
Brake lights and turn signals not working dmc rmx Camaro Discussions 2 04-04-2005 10:41 AM
Back up lights and Turn Signal KissmySS Monte Carlo 0 11-25-2004 01:45 PM
ABS Light and Turn signal went out Can someone Help?? diesel1976 C/K 1 05-05-2004 11:28 PM
Brake lights and turn signals hollandp Sierra 6 02-21-2004 08:17 PM
