Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 04-23-2012, 04:47 PM
SHAMBO's Avatar
SHAMBO SHAMBO is offline
High-speed overheating problem
Hey guys. I have a '69 T-bird. The engine temperature is always normal when I'm driving around the city. When I get on the highway, though, and go 80 mph for just 5 minutes, my engine overheats. I replaced the thermostat but that didn't fix the problem. The radiator and water pump work fine (as far as the mechanics can tell). We checked the engine, too. Compression is good on all cylinders. Also, it passed a block test (there isn't any oil in the coolant).
I can't figure this one out. Any ideas?
Old 05-02-2012, 05:29 PM
joemffields joemffields is offline
Re: High-speed overheating problem
does you fan work properly, does it have a fan shroud, what kind of tranny does it have.
Old 05-02-2012, 05:36 PM
SHAMBO's Avatar
The fan does work and it has a shroud. It's automatic transmission and there is a bit of slippage. I haven't rebuilt the tranny yet. It is very drivable though
Old 05-02-2012, 05:52 PM
when is the last time the coolant has been changed, and what rpm is the engine at 80mph
Old 05-02-2012, 06:12 PM
FishFind FishFind is offline
One Hot Shot
I would check that Rad is clean. Make sure no air in system.
Make sure water pump is moving enough water. Could be bad or you may have a buildup in the Rad or the lines.
You may want to add a separate cooler for the tranny fluid.
Old 05-04-2012, 04:57 PM
SHAMBO's Avatar
The coolant was changed recently. The car doesn't have a gauge to read RPM! But I know it is very high at 80mph because the car only has 3 gears! If I had to guess, I would say it remains at 4500rpm at 80 mph. Now that I think about it...a lot can go wrong when your RPM is that high for 5 or 10 minutes straight!
Old 05-04-2012, 05:28 PM
One Hot Shot
I would look into adding separate cooler for the oil and tranny if you are gonna be driving it at that high of rpm for that long.
Old 05-09-2012, 09:02 PM
SHAMBO's Avatar
good point. thank you
Old 06-01-2012, 07:00 AM
Jeff Collision Jeff Collision is offline
Put a new radiator and water pump. Make sure that the water is overflowing in the pump. Also ensure that the deflector and the fan molding still on the vehicle and the thermostat placed in the vehicle properly.
Old 12-15-2014, 07:15 PM
timd timd is offline
Replace the hoses. At high RPM, hoses may be collapsing.
Vibrations / sound at high speed Elias125 Engineering/ Technical 5 05-19-2010 05:05 PM
94 Corsica Overheating and Spitting Water at High Speeds mgail Corsica 1 08-26-2007 08:28 AM
98 Gr Caravan overheating at High Speeds Timothee Caravan | Voyager 2 02-03-2006 04:04 PM
Overheating, high speed fans not kicking in !!! scyan Montana/Montana SV6 4 05-26-2005 06:03 PM
Overheating, high speed fans not kicking in !!! scyan Venture 3 04-25-2005 09:16 AM
