Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-23-2012, 01:51 PM
rkvons's Avatar
rkvons rkvons is offline
Transmission filler tube seal.
I got this '98 Montana and it has a transmission fluid leak. Our driveway has a slight incline and many times there is this spot under the van that shows a leak. Yesterday, the wife was sitting in the driveway with the engine running for a few minutes and quite a spot was created. So I looked underneath and saw that it was dripping off of the rear of the transmission pan. But it was coming from above that seal. I did some checking online and found out that the trans fluid filler tube goes in on the back of the trans. in that area and it has a seal on it. This might be bad. Now I understand that the filler tube is bolted to the block. My question to you folks is, how difficult is this going to be to replace? I have not looked up in there to see what kind of room I have to work with or anything. The seal is less than a buck. I will be scheduling this job soon. Thanks.
Old 04-23-2012, 08:19 PM
Tech II Tech II is offline
Re: Transmission filler tube seal.
Fairly easy job.....I think it's a 10mm bolt......pull tube out and replace seal......have a pan ready to catch the fluid....
The Following User Says Thank You to Tech II For This Useful Post:
rkvons (04-24-2012)
Old 05-08-2012, 12:40 PM
rkvons's Avatar
So I did this replacement of the Oil Filler tube grommet and it did not stop the leaking. Now I've decided that it must be the pan gasket. About 5 years ago, I did the fluid/filter change and threw away my original pan gasket. The kit I bought had a cork gasket. Well that leaked, so I ordered a Felpro brand gasket and put that on there. It seemed to be okay up until recently. I've ordered the GM gasket and filter and will be doing another fluid/filter change. I've got the 6mm bolts on this pan (20 of them). I was wondering what the torque specs are for these. Thanks.
Remove Transmission Dipstick Tube? MrPedalsworth Town Car 1 07-21-2010 10:23 PM
Leaky Oil Filler Tube gregory914 Suburban 1 04-24-2005 07:13 PM
Oil Filler Tube Removal BlenderWizard Silverado 5 04-22-2005 09:33 PM
How do I remove filler tube on my 74 cuda? SOMMS Engineering/ Technical 1 06-10-2004 10:51 PM
Cracked fuel filler tube moenniv Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-26-2002 01:05 PM
