Old 04-03-2004, 03:46 PM
SOMMS SOMMS is offline
Question How do I remove filler tube on my 74 cuda?
Hello gang,
Newbie here...sorry my first post is a cry for technical help, but if you can help me out I sure would appreciate it.
Here is the deal, 1974 Plymouth Cuda...gas tank is clogged so I am removing it. I have undone most (if not all) of the gas lines and wires between the body and the fuel tank. I have undone the fuel tank straps.
The only thing holding the gas tank to the car is the stupid filler tube. How in the world do I remove the filler tube from the gas tank? It seems there is a rubber grommet type thing that the filler tube fits into but this seems to be attached (quite firmly) to the gas tank. Do I just yank real hard or is there another way to do this?
Thanks a ton in advance.
SOMMS
Old 06-10-2004, 11:51 PM
4cruzin's Avatar
4cruzin 4cruzin is offline
Re: How do I remove filler tube on my 74 cuda?
remove the 4 screws under your license plale and then the only thing that holds it in from there is trunk floor gasket and your tank gasket. alot a wiggling and it should come free. Hope this helps.
HELP!! removing/installing bumper filler (front) youngwit88caprice Caprice 5 06-06-2009 08:06 PM
small hole in gas filler tube batmobile78m Cavalier Problem Diagnosis 1 08-30-2005 10:05 PM
Leaky Oil Filler Tube gregory914 Suburban 1 04-24-2005 08:13 PM
Oil Filler Tube Removal BlenderWizard Silverado 5 04-22-2005 10:33 PM
Cracked fuel filler tube moenniv Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-26-2002 02:05 PM
