Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-21-2012, 11:29 AM
stunter2boy79 stunter2boy79 is offline
98 5.9 no start
truck has 147k, i park it in the driveway after work next day nothing, so i charge the batt due to no lights on dash. now it will crank but wont turn over unless i pump gas pedal then keep foot on pedal. but one take foot off pedal dies. so i been looking at different post and seen one a pick up coil issue and another one was cam senor. no CEL light. has spark n fuel pressure so what could be wrong?
Old 04-21-2012, 11:46 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 98 5.9 no start
Does it run smooth with your foot on the pedal?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-21-2012, 11:53 AM
Re: 98 5.9 no start
yes and no. just went back out and tried starting it. pump pedal again and it ran but dip low rpms but jump back up. shut off and tried starting up and it did but dips low rpms again.
Old 04-21-2012, 12:12 PM
AF - Advisor
Re: 98 5.9 no start
You might try cleaning the Idle Air Control with some carburetor cleaner.
Old 04-21-2012, 12:15 PM
Re: 98 5.9 no start
thanks ill try that then update how it went.
'00 ram 1500 5.9 started running rough bamaboy13 Ram Pickup | Ram SRT10 14 07-03-2012 10:59 AM
2006 Saab 9-5 codes 1301 and 300 nero11 9-5 0 08-06-2009 09:45 PM
2001 Saab 9-5 service soon and code 730 nero11 9-5 0 08-06-2009 09:43 PM
2000 5.9 recently started taking longer to start glura Ram Pickup | Ram SRT10 6 01-01-2006 10:53 PM
