Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 04-19-2012, 09:44 AM
sxdc sxdc is offline
Oil Pressure problem or oil sending unit
I have an 05 Pacific 3.5L with 150k km. The oil light has has started to come on upon start up in the morning, but if I turn off engine and start again immediately the light stays off all day. I checked the oil level and it is fine. It is time for an oil change. Normally I go to Mr. Lube and get the house special but maybe I should think of a higher quality oil and higher quality filter? Maybe the house oil (10W30) loses viscosity over time and miles and the cold start up doesn't have the required pressure so the light gets tripped, then when I do the second start the pressure is there and the light goes out.
Any thoughts on oil quality or filter quality causing this problem? or do you think the sending unit is causing the problem? I'd change the sending unit but it is hidden behind the idler pulley on this model so there is a fair bit of dismantle required to change it, so I don't want to do it just on speculation.
Old 05-02-2012, 06:03 PM
Re: Oil Pressure problem or oil sending unit
Good news. Problem solved. It was the oil sending unit/sensor. It was a bit of a pain to change but the light stays off now.
1997 Park Avenue - Oil pressure at 129psi - sending unit Greg5150 Park Avenue 6 05-30-2010 11:43 PM
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Where is oil sending unit 98 Explorer 5.0 Hedhunter Explorer | Explorer Sport Trac 2 02-13-2010 01:19 PM
Fuel gauge/Sending unit? gspost12 Tahoe 5 02-04-2010 08:36 AM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
