Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-17-2012, 11:02 AM
flash12 flash12 is offline
1995 Regal Transmission problem - Lost R, 3, OD
I have a 1995 regal with the 3.8 that just rolled over 200k. Last week driving home from work I had the cruise set on 65. I slowed down while going through a town and once through hit the cruise back up to 65. A couple seconds later the engine reved up and lost OD. I pulled it down to 3 and nothing. I pulled it down to 2nd gear and I limped it home that way.
When going from P to R...nothing.
You can put it in 1 or 2 and works fine.
If you put in in 3 or D it will shift fine up until it hits 3 and then just revs up.
Am I screwed or is it something simple?
Thanks!
Old 04-17-2012, 06:42 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1995 Regal Transmission problem - Lost R, 3, OD
I don't know if you are screwed or not but you will need a rebuild or replacement transmission given the information you listed. Most electronically controlled transmissions will go in to limp mode when something goes wrong internally. I suggest a local transmission shop to diagnose further.
90 buick regal transmission problems EsQueue Regal 4 12-13-2007 07:24 PM
96 regal, transmission problems TheSilentChamber Regal 8 01-26-2006 02:11 PM
1995 stratus transmission problem djay0270 Stratus 5 08-09-2005 11:42 PM
1995 Regal Tranny Problem KFRG Regal 3 01-31-2005 05:08 PM
1995 z28 transmission problem onekunkel Camaro Discussions 6 08-10-2003 08:16 PM
