Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 04-17-2012, 04:29 AM
4brunner86 4brunner86 is offline
86 4runner problem
Ok so I just put a new 4y engine into my 4b, it's now done 20km and died, every time I put my foot down it dies, so I've done a number of things rebuild the carby, new fuel filters, fuel lines blown out, fuel tank emptied and the fuel pump is new also new fuses after all this she fired first go I got 500m and the same thing happened again has anyone got any surgestions as to what it could be???
Old 04-17-2012, 12:53 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 86 4runner problem
Check to see that the choke sets correctly cold, before starting.
Check the ignition timing.
Check the intake manifold vacuum at idle, hot. This will detect if you have any vacuum leaks.
Check to see that the accelerator pump dumps gas into the carb when you press on the gas.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
'91 4runner urgent question sg4tr4 4Runner/GX470 1 02-12-2011 04:34 PM
1999 Toyota 4Runner Key Problem mmahan69 4Runner/GX470 1 02-02-2011 11:30 PM
1992 Toyota 4runner problems Aph626 4Runner/GX470 1 12-03-2004 11:39 AM
Common 4Runner Problems ak20202020 4Runner/GX470 3 07-08-2004 02:19 AM
'86 4Runner Problem With "On Time" Devise or Starter? 1986NY4runner 4Runner/GX470 6 03-12-2004 06:50 AM
