Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-15-2012, 03:10 PM
97fbird 97fbird is offline
97 firebird starting problems
I have a 1997 pontiac firebird 3.8 V6. When I try starting my car I will have to crank the ignition for about 5-7 seconds before starting up. When it starts up it a little rough for a couple seconds then runs perfectly fine. when it starts I can smell the exhaust smelling rich. I was checking the spark plugs and they seemed oily and smelt like gas. I know this may be a beginning of a bad problem but I dont know where to start.
Old 04-16-2012, 10:40 AM
Tech II Tech II is offline
Re: 97 firebird starting problems
How old are the plugs and wires? Since you are not complaining of a misfire while driving, I would assume coil output is ok.....
Couple of possibilities are: leaking fuel pressure regulator, coolant sensor, fuel pump circuit( not sure if this uses the oil pressure switch as a backup to the f/p relay, if the relay is bad), check fuel pressure on startup, etc.
1996 Pontiac Firebird, Security Problem, Please Help, dshoema2 F-Body Problem Diagnosis 1 01-12-2010 12:31 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
97 Firebird starting problems Glock22shooter Camaro Discussions 2 10-01-2006 08:11 PM
97 firebird starting problems 97fbirdformula Camaro Discussions 4 07-19-2006 10:05 AM
1986 Firebird starting problem gc1566 Camaro Discussions 20 02-12-2005 12:31 PM
