Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 04-15-2012, 02:22 PM
automps automps is offline
Send a message via AIM to automps Send a message via Yahoo to automps
1994 cad eldo w north star stalling
Hello. the map sensor location on the north star engine , Under the intake or there is a sensor bolted to the power brake booster that looks like the old gm map ? Any ideals ..... Keeps shuting off every now and then . Already tryed the crank and cam sensors..... Thanks.....
Old 04-15-2012, 06:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 1994 cad eldo w north star stalling
Map will not cause what you describe plus it would set a code, does it start right up what are the stall conditions?
Old 04-16-2012, 04:09 PM
Yes , it does start right back up ! it has a code for low volts to map , And a load of pcm failure codes . it does not do it all the time , I releaned the idle like the book said.... Ive clean all grounds and connection to the battery.
Old 04-16-2012, 07:50 PM
A990 racer
You need to track down/ diagnose the other pcm failure codes first.
94 Stalls and Fuel Guage is Erratic GMONEY0600 LeSabre 9 05-31-2010 04:36 PM
Antenna / 98 CAD ELDO RENET Eldorado 3 03-10-2006 12:06 PM
