Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-14-2012, 02:25 PM
flyerdan's Avatar
flyerdan flyerdan is offline
18 volts on 84 pickup
Hello, got an 84 2wd xc with a 22R-EC that is putting out around 18 volts at idle. Have replaced the alternator, (and I did have them run the new one up on the test stand first), tried about three different voltage regulators and have removed and cleaned / replaced all of the ground straps from the battery and engine. All the wiring from the alternator has chased out with a continuity tester, wondering where to go from here. Next step will be to open up the factory wire loom and inspect for hidden damage; as far as I can tell it has been unmolested. Any help would be appreciated as this is the last issue keeping it off the road. I have searched extensively on here and other sites for an answer.
Old 04-16-2012, 07:43 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 18 volts on 84 pickup
Are you going by the dash gauge, or an actual voltmeter?
The dash gauges aren't very accurate. The one on my 84 says 18V also, but it's actually less.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 04-17-2012, 01:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
What fourwd1 said. Check the voltage output of the alternator to chassis ground with a good voltmeter.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
GM offers fix for Volt battery concerns AF News Desk Volt 13 03-10-2013 10:00 AM
1954 Ford Pickup sketches_of_b Sketching and Drawing 2 05-06-2012 06:32 PM
Volts Light braleigh Lumina 5 03-08-2010 01:45 AM
Chevy Volt vs Nissan LEAF iafb83 Car Rumors & Concepts 5 01-04-2010 08:07 AM
Volkswagen pickups danbys General Discussion 0 12-21-2009 02:50 PM
