Old 01-26-2010, 03:38 PM
braleigh braleigh is offline
Volts Light
Hi,
I have a 1998 Chevrolet Lumina and the Volts Light came on. My car is running fine and I am still able to use all my lights and radio. I took it in to get fixed and was told that the alternator had a voltage spike and fried the alternator and the PCM. Since the PCM controls more than just the alternator and everything else is still working, is it possble that maybe the Volts light itself is malfunctioning? Or is there maybe and different issue that would not cost me to pay $1500 to fix.
Thank You
Old 01-28-2010, 12:49 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Re: Volts Light
Where did you take it to have it checked out for the problim?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 02-08-2010, 11:53 PM
Probulator Probulator is offline
Re: Volts Light
I'm by no means an expert on ECU's/sensors, but my '98 Lumina did this a few years ago. In my case, the battery was still able to crank and start the engine (barely), but gave a low reading on the multimeter (barely 12 volts [should be 12.4 - 12.65]). This was enough to activate the cryptic 'Volts' light.
I'm not sure you have the same problem. . . I just recommend having the battery tested (if you haven't already) before spending a small fortune on the expensive parts you mentioned. Auto Zone, O'Reileys, NAPA, and other stores that don't actually work on cars are the best. They only run the tests you ask for, and never try to sell you something you don't need.
Old 03-04-2010, 12:35 AM
Tnieves102 Tnieves102 is offline
Re: Volts Light
I am also having a problem with my volt light coming on. Replaced the alternator and battery and now my car starts up and as I soon as i put it in drive it dies and the volts light comes on. Can you tell me what you did to fix this problem?
Thanks
Theresa
Old 03-04-2010, 07:14 AM
Re: Volts Light
Thanks
Theresa
If you have a good battery and a good alternator, the 'volts' light doesn't exactly make much sense. It seems more likely (since you don't have problems until you engage the transmission) that the problem is your transmission. For instance, if the gear you are trying to engage is somehow locked up, it might possibly choke your engine out. Again, I'm not an expert on this subject or this particular problem, and the 'volts' light is confusing as hell.
Old 03-08-2010, 01:45 AM
Bearwulf's Avatar
Re: Volts Light
Theresa:
Try disconnecting the TCC (tourque converter) solenoid. What year is your car?
If you notice, when you first turn on the ignition, the volts light is on. Any time the ignition key is on & engine is not running the volts light will be on because there is no charge being delivered to the battery.
97-Lumina LS
Tags
electrical , light , lumina , volts
