Old 04-14-2012, 11:47 AM
k1979chevy's Avatar
k1979chevy k1979chevy is offline
IH Country Boy
AC Clutch, ABS Ignition Fuse keeps blowing, Help!!!
This problem is really testing my patience. I have a 1999 pontiac grand prix gt, 3.8l. The AC clutch/ABS ignition fuse keeps blowing. But only when you turn the AC on. So i replaced the relay with a differnt one. It still blew. So i unpluged the diod. It still blew. So i unpluged the AC Clutch wire contection. It still blew. What is going on with it? I Dont know what the problem is and any help would be great! Thank you so much for any help.
My shop teachers famous words: "Dont be stupid!"
1999 GP GT 3.8L 190k miles
12" brake conversion, flipped motor mounts, Analog to Digital DIC Conversion
Drilled 180 degree thermostat, 1 1/4in thick Radiator
Old 04-14-2012, 09:02 PM
Tech II Tech II is offline
Re: AC Clutch, ABS Ignition Fuse keeps blowing, Help!!!
You have a short somewhere when the A/C is commanded on.....
Remove the relay....turn A/C on....does the fuse still blow? If it doesn't, then the problem is in the circuit between the relay and the A/C clutch...A way to verify this, is to disconnect the harness to the A/C clutch, remove the diode again, attach a test light to the battery positive, and with the other end, probe the green wire in the clutch harness...if it lights, there is a short somewhere in the circuit, since you have removed the A/C relay.....
Old 04-14-2012, 10:23 PM
k1979chevy's Avatar
IH Country Boy
Thanks. I will try that this week and see what happens.
ignition fuse keeps blowing. cwetherington Stratus 18 09-08-2015 05:07 PM
Help Please I Dont Want To Buy Another Car!! Ignition Fuse Keeps Blowing!!!! 94parkaveultra Park Avenue 5 03-11-2005 09:30 AM
ignition fuse keeps blowing silversenn S-10 3 12-15-2004 10:40 PM
Ignition fuse keeps blowing ryanm75 M Bodies 1 12-04-2004 01:13 AM
My ignition fuse keeps blowing out in my 91 talon Black_Wido_Talon Off-Topic 2 03-07-2004 07:27 PM
